40
Delete the series
When an appointment is to be deleted if it is recurring the schedule shows the dialog "Would you like to delete the occurance or series ?".  If the user clicks series, all appointments in the series are quickly removed. Which method to call to delete the series ?
  • 69832
    Suggested Answer
    I believe you just have to delete the recurring appointment root; doing this will cause it to be disposed, which will in turn cause its assigned recurrence to be disposed, which causes all the occurrences to be removed as well.
