Hi
We are using Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter for exporting UltraGrid data into Excel Sheet.
For high volume data (Near about 1,000,000 Records) it takes considerable time to Export.
User requires cancel to export functionality if this scenario occurs.
Could you please provide your inputs, how to implement the cancel option with paging of this data for Export.
(Progress bar with Cancel option, Cancle the export will save the records already exported)
Same case With PDF Export as well
You could handle the InitializeRow event of the UltraGridExcelExporter. The event args for this event has a property called TerminateExport. Setting this to true will stop the export.
However, the firing of InitializeRow is pretty quick, and it's probably not the major portion of the export process. And once the InitializeRow has fired for all of the rows and the excel file is being written, there's no way to stop the exporting at that point.
