An ultrcomboeditor with the Drop down style set to Drop Down with AutoCompleteMode as SuggestAppend and LimitToList as true. During runtime I set the appearance backcolor property to Color.FromArgb(216, 228, 248). But it displays the text portion of the combo box as white. I tried with various events like enter and leave. But it didn’t work.
I am using Visual Studio 2008 with .NET Framework version 3.5 and Infragistics 2009 volume 1.
Please help me regarding this issue.
I was not able to reproduce the issue you describe here with the latest build of 2009.1. You might want to doanload the latest version and try with that; if the problem persists report it as a bug.
I am using Infragistics version 9.1.20091.1000 only. I also found this is a bug in windows control.
Please verify this link, http://connect.microsoft.com/VisualStudio/feedback/details/532834/combo-box-with-dropdownstyle-property-set-to-dropdown-does-not-display-backcolor-properly#
I change appearance.backcolor when i got focus in this control, whrn i leave this control i rest it to white. But the problem it is changing the color.
I'm afraid I might have misunderstood your problem. The link you refer to here has nothing to do with our control because we don't use a ComboBox. If you are using our UltraComboEditor, my original response applies - I cannot reproduce with the latest version and the details you provided here, so you should consider trying with the latest build.
