I have a Form with UltraDockManager that include 3 windowDockingArea
explorerBar - dock Left
panel1 - dock Left
RightPanel - dock Right
when I Press on Pane Button and the state of RightPanel panel is change,
The display of all form is damaged,
A part of Form and the frame, disappear .
Is it bug?
Or you have a Solution?
Its very important me!
It is difficult to determine what the issue might be without seeing a sample. You should probably work with a Developer Support engineer to determine if this is a bug or not. I have forwarded this post to the Developer Support Manager and a DS engineer will be contacting you about this issue.
