I'm using the provided GanttDataSource class as the datasource for my Gantt Chart. I manually create GanttSeries, GanttItem, and GanttTimeEntry objects with data provided by custom business classes, and add them to the GanttDataSource. When I bind my GanttChart to the GanttDataSource, the box primitives, representing gantt item time spans, do not line-up with the chart dates displayed upon the x-axis. Also, I haven't been able to get the Series labels to display upon the y-axis. Box primitives and Series labels display properly, if the design-time chart designer is used to manually enter Series, Item, and Time data.
Does anyone know what might be causing the box primitives to not line-up with the x-axis?
try setting Axis.X.TimeAxisStyle.TimeAxisStyle = Discrete. that should make labels line up with actual data values on the X-axis.
as for series labels on the Y axis... they should just display if you have the Label property of each GanttSeries set. does increasing the Y axis extent show them?
Thank you David! Your solution fixed the issue that I was having.
CPatrick
