In the default KeyActionMappings, there's an entry for the Left keycode with:ActionCode=CollapseRow, StateDisallowed=Cell, StateRequired=RowExpandable Or RowExpanded
It doesn't work for me - I can't get the Left key to collapse the row. I've tried clearing everything from KeyActionMappings except this line, and even replacing it withActionCode=CollapseRow, StateDisallowed=0, StateRequired=0
but nothing works. What am I doing wrong?
This was accepted as a bug by Mike Saltzman on 16/02/2010 (http://community.infragistics.com/forums/t/38017.aspx). No solution or workaround suggested.
Hello Paul,
Which version of NetAdvantage are you using? I tested the issue in NetAdvantage 2010 Volume 2 build 2058 and the left arrow key worked properly.
Hi Dave,
No, I'm using 2010 Volume 1. Sounds like I need to upgrade.
Paul
If you don't want to upgrade to NetAdvantage 2010 Volume 2, you could just install the latest Service Release for NetAdvantage 2010 Volume 1. That way you wouldn't have to change any of the references in your projects as long as the SpecificVersion property is set to false.
Thanks Dave. I've downloaded the latest Service Release and it fixes the problem.
