Hi all!, I have a little problem, when I change the BackColor property of a row, I see that the Background around the slash of the dates are still white, as you can see in the images:
This is the code I use to change BackColor property:
grdFincas.Rows[i].Appearance.BackColor =
.FromArgb(181, 255, 181);
Please, can anybody tell me what am I doing wrong?.
Thank you very much in advance for your help!.
Regards.
The only thing I can think of that might cause that would be if you set an appearance that affects only literal characters in our masked editor. If you want you can attach a sample here and we can take a look.
Hi! Here is the file we use to set the appearance. It´s a XML file with isl extension.
Hi all guys!, problem solved!. It only was a matter of adding two lines setting the style and format for those column which were to show dates.
ultraGridColumn9.Style =
ColumnStyle
.Date; ultraGridColumn9.Format =
"dd/MM/yyyy"
Guillermo Tejedor.
