I am using Infragistics.Win.UltraWinSchedule.UltraMonthViewMulti, I've set the 'YearScrollButtonVisible' to false. Now according to the requirement I am using windows buttons and then trying to scroll thru years on the calendar but I am not able to change the year, even after loading the dates, on the UI current year is kept as selected, even I try to increment/decrement the year. Which property do I need to set for getting it work through code.
The control exposes a settable FirstMonth property, which is of type Infragistics.Win.UltraWinSchedule.Month. You can get a reference to a Month object using the UltraMonthViewMulti.CalendarInfo.GetMonth method.
Hi Brian,
Thanks for your reply. It worked for me.
I need help on two more issues,
1. Is there anyway by which we can set the font for the date numbers in months and text also ?
2. In months view, i want to set the border of the dates such that their appearance is Striking Out, normally we have 'Offset' property for borders to make this behavior, but for control i didn't find anything, please suggest.
Ashutosh
