I have an Ultrawingrid with column type as UltraWinGrid.ColumnStyle.DateTimeWithSpin
I have set the column format as
.DisplayLayout.Bands(0).Columns( "Column1").Format = "Column1").Format = "MM/dd/yyyy HH:mm" When the grid enters into edit mode, the column format changes to default (i.e)12 hours time format instead of 24 hours time format. Can u pls help me on this issue
"Column1").Format =
"MM/dd/yyyy HH:mm"
When in edit mode the InputMask controls the display of the data. You can see more details on setting the InputMask in the help:
http://help.infragistics.com/NetAdvantage/WinForms/2011.1/CLR2.0/?page=Infragistics2.Win.UltraWinGrid.v11.1~Infragistics.Win.UltraWinGrid.UltraGridColumn~MaskInput.html
Let me know if you have any questions with this matter.
