I want to use the following so that when a group is collapsed you can still see the totals.When it's expanded though, I think it's confusing to show this and the same total at the bottom of the group. Therefore I only effectively want BottomFixed and GroupByRowsFooter in this case.This question was asked years ago on the old forum. Is there now any way to achieve this without draw/creation filters?
E.g. are there some events I could trap instead and stop the summary displaying?
DisplayLayout.Override.SummaryDisplayArea = SummaryDisplayAreas.BottomFixed;DisplayLayout.Override.SummaryDisplayArea |= SummaryDisplayAreas.InGroupByRowsDisplayLayout.Override.GroupBySummaryDisplayStyle = GroupBySummaryDisplayStyle.SummaryCells
No, there's no way to do this automatically. Removing the summaries from the GroupByRow when the row is expanded should be a pretty simple CreationFilter, though.
HI Mike,
I Want to Group By Summary,
Eg,
I'm not sure what you are looking for here. Are you asking a question? What part of this are you having trouble with? Is this related to the original post in this thread?
To do what you have here you just using the grid's summaries in conjunction with OutlookGroupBy.
