For an ultraTree with Outlook ViewStyle, iam trying to change the backcolor of cells of a node, but the backcolor only effects to the parent node not the child node.
This is what i am trying to do!
foreach
(var node in ultraTree.Nodes)
(var eachCell in node.Cells)
cell.Appearance.BackColor = Color.Red;
Please, can you help me, whats going wrong with this?
Sami.
Hi Sami,
The BackColor only affects the root node because you are only looping through the root nodes.
The nodes of a tree are in a hierarchical tree structure. So if you want to loop through every node in the tree, you would have to do it recursively. In other words, for each node in your loop, you would have to loop through node.Nodes. And then the child nodes of those nodes, etc.
If you just want to color all of the cells in a column, though, it's much easier and more efficient to apply an appearance to the column, instead of every individual cell.
Hi Mike,
It works. Thanks a lot!
