Hi Mike,
I want to have checkbox for each dropdown item of Ultra-combobox. Do we have any such feature for combo-box. I need to do this to select multiple items at same time and then submit the form..
How can I implement this.. ?
Selecting Multiple Values within WinComboEditor
Thanks a lot...It was of great help to me...... :) :) :)
One more question , I have in my mind. I have a user-control which is having one ultra-combo box . I want to use this user control in other 3 main screens of my application at proper location. How can I do that ?? How to use one user control inside other user-control's designer .
I'm afraid I do not understand your question. What part of this are you having trouble with?
Using a UserControl doesn't really have anything specifically to do with the Infragistics controls. A UserControl is a Control like any other control. Typically, you would just drag it or double-click it in the toolbox to place it on a design surface.
Which version of Infragistics supports this multi select combo editor with check box ?
Also is there a way to implement the same using Infragistics 6.3?
Mukhil
Hi Mukhil,
I'm not exactly sure when this feature was added, but I am sure it was not available in v6.3. If you want to use this feature you will need to update to the latest version of NetAdvantage.
