I am currently using NetAdvantage 2010 and with the new ApplicationMenu2010 i have set a tool as a PopupControlContainerTool. Inside the container is a control with various TextBoxes.
The problem is that I want to navigate the controls using the tab key however the ApplicationMenu2010 starts tabbing instead. How do I keep the tabbing to within the container control?
Thanks.
I have test your scenario with Infragistics 10.3, and I was not able to reproduce your issue. I am attaching the sample with which I made my tests.
Run the sample, press “R” then “P” in order to expand PopupControlContainer1, then press “Tab” in order to navigate through the control in the popup. So please download the latest service release of the Infragistics components of the volume that you are using and test your scenario. This Service release should be available under your account at the Infragistics Website. To download the service release, log in to
‘My IG’ and select ‘Keys & Downloads’. Select the appropriate tab for this product, then the license key. The available service releases should now be listed on the page.
Hi Hristo,
The example you have provided me with functions correctly until you set the Ribbon.FileMenuStyle = ApplicationMenu2010. Then the tabbing problem is still present. I will apply the service packs and try again and see if the problem still lies.
I have tested your scenario with the latest service release of 10.3, which is 2067 and also set Ribbon.FileMEnuStyle to ApplicationMEnu2010 and the sample still working for me. Please let me know what are the results after you upgrade to this service release.
Thank you.
The latest service release has fixed the problem. Thanks for you help. Much appreciated.
