155
New Row Sorted position with grouping
I have a ultrawingrid binded to a datatable through bindingsource. If I add new rows to the underlying data-table its populating the grid appropriately. The problem is when I add a new row to the datatable & grid has sorting on 1 field & grouping also in the other field. The new row is not getting sorted within the group.
If i remove the grouping, then I can place it properly by calling RefreshSortPosition() on the bottom row. But its not working with the grouping on (probably because of the grouping as it will not be last row).
Is there a way to sort the new row properly inside the group ?
