Hi guys,
I'm working with the UltraFormattedEditor.
Is it possibile to change any property the editor so that method PerformAction(FormattedLinkEditorAction.ToggleBold, false, false); writes short tags (<b>) into the value instead of (a.e <span style=\"font-weight:bold;\"> )?
Kind regards
David
Hi David,
No, there's no way to do this. You can Submit a feature request to Infragistics.
You could, of course, attempt to do a Replace on the control's value. But this won't always be reliable, since it's possible that there will be more than one style applied to the same block of text.
