I have a ultrawingrid (only few columns are editable) which is populated on page_load, user enters values or selects a value from dropdown.
On a button click event I should validate all the editable cells of the grid for null values and highlight all the null values cells with some background color.
Hello Ramesh925,
I have implement two possible approaches for you in the code shown at the end of the forum thread.
In the first approach I am iterating through all the cells and setting the Red backColor of those that match the null condition. (ultraButton1_Click)
In the second approach I am setting the valueBased appearance on the desired columns(ultraButton2_Click)
Please let me me know if you have any other questions with this matter.
OperatorCondition condition1; Infragistics.Win.Appearance appearance; ConditionValueAppearance valAppearance; public Form1() { InitializeComponent(); DataTable dt = new DataTable(); dt.Columns.Add("String1", typeof(string)); dt.Columns.Add("String2", typeof(string)); dt.Columns.Add("String3", typeof(string)); dt.Rows.Add("a", null, "c"); dt.Rows.Add("a", "b", "c"); dt.Rows.Add("a", "b", null); dt.Rows.Add(null, "b", "c"); dt.Rows.Add("a", null, "c"); dt.Rows.Add("a", null, "c"); dt.Rows.Add("a", null, "c"); dt.Rows.Add("a", "b", null); dt.Rows.Add(null, "b", "c"); ultraGrid1.DataSource = dt.DefaultView; condition1 = new OperatorCondition(ConditionOperator.IsNullOrEmpty, DBNull.Value); appearance = new Infragistics.Win.Appearance(); appearance.BackColor = Color.Green; valAppearance = new ConditionValueAppearance(); valAppearance.Add(condition1, appearance); } private void ultraButton1_Click(object sender, EventArgs e) { foreach (UltraGridRow row in ultraGrid1.Rows) { foreach (UltraGridCell cell in row.Cells) { if (cell.Value == DBNull.Value) { cell.Appearance.BackColor = Color.Red; } } } } private void ultraButton2_Click(object sender, EventArgs e) { ultraGrid1.DisplayLayout.Bands[0].Columns["String1"].ValueBasedAppearance = valAppearance; } }
