150
UltraTree Cell Edit error with context menu
Hi
i'm using an UltraTree with editing mode enabled but when editing, if the user right clicks and selects 'Add new child’ the Tree throws an exception when I try to end edit mode and add a new row. I also tried just exiting the context menu and not allowing an add new to execute but even doing this the tree disables editing of the cells and in some cases rows cannot be selected again.
        Me.TreeControl.Override.LabelEdit = Infragistics.Win.DefaultableBoolean.True 'enables F2 editing
        Me.TreeControl.Override.Multiline = Infragistics.Win.DefaultableBoolean.False
        Me.TreeControl.Override.LabelEditAppearance.BackColor = Drawing.Color.LightYellow
        Me.TreeControl.Override.UseEditor = Infragistics.Win.DefaultableBoolean.True
        Me.TreeControl.Override.Editor = New Infragistics.Win.EditorWithText()
    Protected Overridable Sub onTreeAddChildClicked(ByVal Sender As ObjectByVal e As EventArgs)
        Try
            ' This kills off editing at the row level. The cell does not highlight when selected and often the blue "selected" background is left in place (even when not selected)
            If _TreeControl.ActiveNode.IsEditing Then
                Exit Sub
            End If
            ' Kills the controls and disables it perminately. The control has Red Cross displayed, exception thrown.
                Me.TreeControl.PerformAction(UltraTreeAction.ExitEditMode, FalseFalse)
                Exit Sub
            End If
            ' CODE TO ADD NEW CHILD ROW
        Catch ex As Exception
        End Try
    End Sub
Questions:
Apart from disabling the context menu is there any way to get the control out of edit mode and/or reset it?
I get 2 slightly different exceptions depending on what action is taken in the context menu event. If just exitedit mode, the first exception is thrown, if exitedit mode and attempt to insert new row I get 2nd exception (note the key used on the newly inserted row is not a duplicate and is not the key mentioned in the exception)
I would appreciate any help with this.
Object reference not set to an instance of an object.
       Source Assembly: Infragistics4.Win.v11.2
       Method: OnTextBoxTextChanged
       Stack Trace:
          at Infragistics.Win.EditorWithText.OnTextBoxTextChanged(Boolean fireValueChanged)
          at Infragistics.Win.EditorWithText.Infragistics.Win.IEmbeddableTextBoxListener.OnTextChanged()
          at Infragistics.Win.EmbeddableTextBox.OnTextChanged(EventArgs e)
          at System.Windows.Forms.TextBoxBase.WmReflectCommand(Message& m)
          at System.Windows.Forms.TextBoxBase.WndProc(Message& m)
          at System.Windows.Forms.TextBox.WndProc(Message& m)
          at Infragistics.Win.EmbeddableTextBoxWithUIPermissions.WndProc(Message& m)
          at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
          at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
          at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
          at System.Windows.Forms.UnsafeNativeMethods.SendMessage(HandleRef hWnd, Int32 msg, IntPtr wParam, IntPtr lParam)
          at System.Windows.Forms.Control.SendMessage(Int32 msg, IntPtr wparam, IntPtr lparam)
          at System.Windows.Forms.Control.ReflectMessageInternal(IntPtr hWnd, Message& m)
          at System.Windows.Forms.Control.WmCommand(Message& m)
          at System.Windows.Forms.Control.WndProc(Message& m)
          at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Item has already been added. Key in dictionary: 'Watch List'  Key being added: 'Watch List'
       Source Assembly: mscorlib
       Method: Insert
       Stack Trace:
          at System.Collections.Hashtable.Insert(Object key, Object nvalue, Boolean add)
          at System.Collections.Hashtable.Add(Object key, Object value)
          at Infragistics.Win.UltraWinTree.NodeClientAreaUIElement.CacheNodeElements(Hashtable table, UIElementsCollection oldElements, Int32 startIndex)
          at Infragistics.Win.UltraWinTree.NodeClientAreaUIElement.PositionChildElements()
          at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
          at Infragistics.Win.UIElement.VerifyChildElements(Boolean recursive)
          at Infragistics.Win.UIElement.VerifyChildElements()
          at Infragistics.Win.UltraWinTree.UltraTreeUIElement.PositionChildElements()
          at Infragistics.Win.ControlUIElementBase.VerifyIfElementsChanged(Boolean verify, Boolean syncMouseEntered)
          at Infragistics.Win.ControlUIElementBase.VerifyIfElementsChanged(Boolean verify)
          at Infragistics.Win.ControlUIElementBase.ProcessMouseMoveHelper(Object sender, MouseEventArgs e)
          at Infragistics.Win.ControlUIElementBase.ProcessMouseMove(Object sender, MouseEventArgs e)
          at Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e)
          at Infragistics.Win.UltraControlBase.OnMouseMove(MouseEventArgs e)
          at Infragistics.Win.UltraWinTree.UltraTree.OnMouseMove(MouseEventArgs e)
          at System.Windows.Forms.Control.WmMouseMove(Message& m)
