40
Project upgrade
I need to upgrade an old project to 2009.2 version of winforms controls, due to the error described here: http://blogs.infragistics.com/forums/t/41560.aspx
But when I try to launch the upgrade utilities I get some errors that I cannot understand/solve, both using the utility and the vs plugin.
I will report below the error from the upgrade log file, anybody has any hint?
Thanks a lot
Andrea
10:24:11: Running VS2010 Add-in UI Version 11.2.20112.1000
10:24:11: Gathering volume and assembly information.
10:24:13: ProjectFile element: AladinoSFA2\AladinoSFA2.csproj is being treated as a proj file.
10:24:13: Analyzing AladinoSFA2.csproj...
10:24:13: The project has references that need to be updated.
10:24:14: Could not load the project. Please see the Log file for more details.
10:24:14: Object reference not set to an instance of an object.
10:24:14:    at Infragistics.VersionUtilitySupport.Core.File.Types.ProjectFile.CheckProjectForAdditionalFiles(Boolean isSLProject, Boolean isWP7, XmlNode node)
   at Infragistics.VersionUtilitySupport.Core.File.Types.ProjectFile.Analyze()
Parents Reply Children
No Data
