2145
Choosing what to exclude rather than include when using SaveAsXML
Hopefully this post may help others and act as a possible feature request.
What I am trying to do save a layout to the database (works fine) but not without filters. However to do this I clear the filters before saving, my problem then lies in restoring the filters after the save.
It would be handy if I did not need to clear them and just choose what to exclude rather than include the one thing I do want when saving with SaveAsXML.
To solve this I first tried making a copy of the old filter settings with the following line:
oldfilters = ugrScenario.DisplayLayout.Bands(0).ColumnFilters
To restore it after clearing and saving it using:
ugrScenario.DisplayLayout.Bands(0).ColumnFilters.CopyFrom(oldfilters)
However nothing appears to happen. In the end I got around it by using another SaveAsXML the filter layouts option only to a file, clear the filters and load that file back in again. Seems like a sledge hammer to crack a nut but it does work as a workaround:
'Save the filters to a temporary file.
ugrScenario.DisplayLayout.SaveAsXml(gDBfolderpath & "\Temp.xml", PropertyCategories.ColumnFilters)
'Clear the filters.
ugrScenario.DisplayLayout.Bands(0).ColumnFilters.ClearAllFilters()
'Save the full layout to a file, or file stream in this case (ms).
ugrScenario.DisplayLayout.SaveAsXml(ms, Infragistics.Win.UltraWinGrid.PropertyCategories.All)
'Restore the filters from the file and delete the file.
ugrScenario.DisplayLayout.LoadFromXml(gDBfolderpath & "\Temp.xml", PropertyCategories.ColumnFilters)
File.Delete(gDBfolderpath & "\Temp.xml")
