What property should I set so that I can select cells in multiple rows only from those columns which are being dragged, as we do in Excel.
At the moment when I drag in particular column(s) downward, it also selects the cells from other columns which are not dragged.
Please see below the screen shot of what I need.
Can someone please reply to this urgent query?
Maybe one possible way to achieve desired behavior could be if you are using the proeprties below:
private void ultraGrid1_InitializeLayout(object sender, InitializeLayoutEventArgs e) { e.Layout.Override.SelectTypeCell = Infragistics.Win.UltraWinGrid.SelectType.ExtendedAutoDrag; e.Layout.Override.SelectTypeCol = Infragistics.Win.UltraWinGrid.SelectType.Single; e.Layout.Override.SelectTypeRow = SelectType.Extended; e.Layout.Override.CellClickAction = Infragistics.Win.UltraWinGrid.CellClickAction.CellSelect; }
Regards..
Thanks for providing the solution.
There is still one issue that is that it selects all the cells of the last row in selection.
That worked for me. Thanks.
