Hi there,
I'm not sure where to look for this but when I try to format data inside the UltraDesktopAlertShowWindowInfo control, some HTML tags seem to be valid while others just get ignored. For example <br /> tags seem to work but table tags don't.
Essentially what I want to know is - is there a way to display tabular data inside a UltraDesktopAlert control? My understanding was that I had to use the UltraDesktopAlertShowWindowInfo.Caption to do this - but it doesn't seem to work very well.
Hello Samuel,
The UltraDesktopAlert does not support the full set of HTML tags. The document at the following location provides the tags that are supported by the control.
http://help.infragistics.com/NetAdvantage/WinForms/2012.1/CLR2.0/?page=WinFormattedLinkLabel_Formatting_Text_and_Hyperlinks.html
