I am tring to use a bound control derived from the numericeditor. In the derived control I need to find out if the number in the next record the control should display will exceed the maximum value for the control. As yet I have been unable to find an error being thrown, but when there is a value that exceeds the max for the control it looks like the next record cannot be scrolled into. I can jump past it however. Any suggestions? Thanks
If the control is bound, then the exception will be caught and handled by the binding.
You might want to check out this post: http://forums.infragistics.com/forums/p/6070/29885.aspx#29885
I think this is the same issue you are having.
