scrollBarLook1.ScrollBarArrowStyle = Infragistics.Win.UltraWinScrollBar.
the code above did not do it note the below comment from infragistics
//Note: Under Windows XP if the ‘SupportThemes‘ property // is left set to True (its default setting) then some of // the explicit appearance and button style property // settings are ignored. //UltraScrollBar sbar = this.ultraScrollBar1;
//sbar.SupportThemes = false;
but ScrollbarLook does not have a SupportThemes property, any idea how to set that if that's what makes
the arrow showing on the scroll bar ignored?
Thanks the issue was resolved, some body was redrawing the vertical scroll bar rectangle after disabling the horisontal scrollbar but when that happened the arrows on the scroll bar were gone, I fixed the offensive code
thanks for the help anyway.
I appreciate it
