I have a base form which has a UltraGrid. The child form derives from the base form. I bind the data source with the child form. However, I can't modify any cells on the grid although the isReadOnly property of each column is false and CellActivation is AllowEdit.
If I created a UltraGrid on the child form instead of using one from the base form, I can edit the cell.
Please help!
Thanks!
Since no one answer the question, I answered it by myself. I need to Change the following property of UltraGrid from CellSelect to EditAndSelectText:
DisplayLayout | Override | CellClickAction.
Iam looking for changing this property for only one column, is this possible, too?
CellClickAction was added to the Column in a recent version of the grid. I don't remember exactly what version. But if you don't see the property on your columns, then it must have been added in a later version that you are using.
