Hello Folks. Please i have the following problem:
I have a form A1 with the property IsMdiContainer=True with an UltraExplorerBar on it. In the UEB i have added some groups and Items.
I have another form called B1 with a buttons,labels,comboboxes on it.
When i click on some item on the UEB (A1 form) i want the form B1 to be shown.
private void ultraExplorerBar1_ItemClick(object sender, Infragistics.Win.UltraWinExplorerBar.ItemEventArgs e) { switch (e.Item.Tag.ToString()) { case "CustomersIncidents": CustomersIncidents B1 = new CustomersIncidents();B1.MdiParent = this;B1.Show(); break;
The B1 is added to my form A1 but without the buttons and the other controlers !
Should i add something else ?
Thanks for your help :)
If I understand you correctly your MDI child form shows and the issue is all the controls are missing from the form. One possible reason for this could be if you do not call the InitializeComponent method of your child form.
However in order to investigate this issue in deeper details I will need a small sample solution showing this behavior. So please try to isolate this behavior in a small project and send it to me for further investigation.
I am looking forward to your reply.
Thanks for your reply.
Please find enclosed a small sample solution showing the probleme.
When i click on item Customer or ITO i want the MDI shows me the corresponding MDI child form full with controllers.
Thanks again :)
Bellow the link to the project.
https://drive.google.com/file/d/0B4Bu5PVsVQLSMC03dWJNVVhUWWM/view?usp=sharing
For some reason I cannot download the project from the link provided. It says "You need permissions to access this file".
Please put your project in zip archive and try to upload it here, or you can send me the archive via email at support@infragistics.com. Please add this number as a subject of your email CAS-154922-S2K5S3.
Looking forward to your reply
I am just checking about the progress of this issue. Let me know if you need my further assistance on it.
