Hi all.
It is possible to show a label with continuous numbering in the row (record) header? Many thanks for any hints.
Phil
Hello Phil,
I have been looking into this for you and even though there is no such built-in functionality I found a forum thread that discusses the same issue. Please look through this thread:
http://news.infragistics.com/forums/t/40391.aspx
where there is an attached sample illustrating an approach you can use.
I am looking forward to hearing from you.
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
If this is what you were looking for please verify the answer so it helps other users as well.
