Hi
I have an implementation where XamDataGrid is being used. In the XamDataGrid I have a column where the value (a number) is to be changed to a corresponding text given some states.
First of all I need to have the multibinding as twoway for it to work ? If using oneway for the multibinding then it stops working.
Secondaylly, it works initially, but when editing a row, which changes the state, sometimes the number is shown instead of the text and this happens when the ConvertBack is called. I really have difficulties to implement a convertBack due to the logic, so I would like to have this to work with oneway. Se below code, where the TypeIdToTextConverter is twoway, and doesn't work if set to oneway.
<dP:Field Name="RecordType" FixedLocation="FixedToNearEdge" Width="70"> <dP:Field.Settings>
<dP:FieldSettings.EditorStyle> <Style TargetType="{x:Type igEditors:XamTextEditor}"> <Setter Property="Value"> <Setter.Value> <MultiBinding Converter="{StaticResource TypeIdToTextConverter}" > <Binding Path="Cells[RecordType].Value" Mode="OneWay"/> <Binding Path="Cells[NonVerifiedData].Value" Mode="OneWay"/> <Binding Path="Cells[NormalOperation].Value" Mode="OneWay"/> <Binding Path="Cells[CompleteRecord].Value" Mode="OneWay"/> <Binding RelativeSource="{RelativeSource AncestorType=dP:XamDataGrid}" Path="DataContext.DowntimeRecordState" Mode="OneWay"/> </MultiBinding> </Setter.Value> </Setter> </Style> </dP:FieldSettings.EditorStyle>
How can I make this work ?
Hello Dennis,
As I could see you are having the same discussion with Rob about this. So I just wanted to update the thread with a link to that discussion so other community members could benefit from it as well:http://www.infragistics.com/community/forums/t/101468.aspx
