I am using a XamDataChart in my WPF application and I am using Infragistics WPF 2015.2.
When I am using the XamDataChart with the mouse all events are fired as expected.
When I am doing the same with a touch screen then I expect the same behavoir like for a standard WPF control (e.g. label) but with the XamDataChart I am missing the PreviewMouseDown / MouseDown event.
Standard behavior on touch:
XamDataChart behavior on touch:
Is this an intentional behavior (e.Handled = true in TouchDown?) or a bug in XamDataChart? If it is an intentional behavior is it possible to suppress this behavior?
Thank you in advance
André
Hello Andre,
Thank you for your post.
The behavior that you are currently seeing with the XamDataChart touch events appears to be intentional. I have been looking into the source code of the XamDataChart, and it appears that we are handling the Touch-related events internally. As these touch-related events are handled, the WPF framework will not send the mouse events, as they are essentially ignored.
I don't believe there currently exists a way to suppress this behavior in the chart at the moment, but you may want to consider following the examples given at the following forum thread about raising your mouse event handlers in your touch events: http://stackoverflow.com/questions/11245551/how-to-get-touchscreen-to-use-mouse-events-instead-of-touch-events-in-c-sharp-ap.
Sincerely,AndrewAssociate DeveloperInfragistics Inc.www.infragistics.com/support
Hi Andrew,
thanks for answering my question. That helps me a lot.
Best regards
