I need to Filter set of data and allow user to edit/delete results after filter is applied. I am trying to find a way to get handle on Result (subset of original records after filter applied.
Hello Rajish,
You can use the GetFilteredInDataRecords /GetFilteredOutDataRecords methods to get the data records that match / do not match the filter criteria e.g. For example in the event handler of RecordFilterChanged event of XamDataGrid you can use the GetFilteredInDataRecords method of RecordManager:
private void xdg_RecordFilterChanged(object sender, Infragistics.Windows.DataPresenter.Events.RecordFilterChangedEventArgs e){ IEnumerable<DataRecord> filteredInRecords = xdg.RecordManager.GetFilteredInDataRecords();}
Sincerely, ZhivkoEntry Level Software Developer
Thanks for the info. This is what I was looking for. :)
Hi Rajish,
I am really glad, I could help out. If you do not have any further questions, please verify this thread as answered, so it helps other users as well.
