Hi ,
I m going to write new Well plate control for our scientific sofwtare (see attached screenshot). This plate control has dynamic number of Columns and rows . It should be able to visualie Datapoints , graphview and Images in every well . Also should be able to show the data in real time while measuring .
Does using XamChart is good choice for creating this PlateControl ? Or who could suggest better infragisitics control or better approach ?
Hello Franco,
Thank you for contacting Infragistics. We do not have a WellPlate control or series for the XamDataChart. Based on the image you've provided it could use our XamSpreadSheet control and place images within each cell.
eg.
http://www.infragistics.com/help/wpf/igexcelengine-addingimagetoworksheet
I recommend submitting a new product idea as well. You can suggest new product ideas for future versions (or vote for existing ones) at <http://ideas.infragistics.com>.
There are many benefits to submitting a product idea:
Direct communication with our product management team regarding your product idea.Notifications whenever new information regarding your idea becomes available.Ability to vote on your favorite product ideas to let us know which ones are the most important to you. You will have ten votes for this and can change which ideas you are voting for at any time.Allow you to shape the future of our products by requesting new controls and products altogether.You and other developers can discuss existing product ideas with members of our Product Management team.
Steps to create your idea:
1. Log into the Infragistics Product Idea site at http://ideas.infragistics.com (creating a new login if needed).
2. Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)
3. Add your product idea and be sure to be specific and provide as much detail as possible.
- Explain the context in which a feature would be used, why it is needed, why it can't be accomplished today, and who would benefit from it. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. Be convincing!
- Include a link to this thread in your idea so product management will be able to look back at this case.
The Product Idea site puts you in the driver's seat and allows you to track the progress of your ideas at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
Let me know if you have any quesitons regarding this matter.
Thanks for the suggestion . :)
I started with cretaing small demo with XamSpreadSheet.
But how can hide the blank columns and rows ?? (see scrrenshot)
Regards
Both WorkSheetRow and WorkSheetColumn contain a Hidden property which you can set on your Worksheet. The columns and rows within the Spreadsheet are not visual elements you can configure directly.
Let me know if you have any questions regarding this matter.
Thanks .
But there is no way to not add or cretae blank columns or rows in first plcae ? Just cretae a worksheet with (3 columns - 2 rows) for example .
Thank you for following up. The XamSpreadsheet and Worksheet object contain a near infinite amount of rows and columns by default and do not allow you to hide unused cells, rows or ranges easily.
This and a Well Plate control are considered to be a new product ideas. You can suggest new product ideas for future versions (or vote for existing ones) at <http://ideas.infragistics.com>.
