145
SpinnerSegmentedBusyAnimationPresenter missing
I used the Samples Browser to generate a style for a busy indicator.  Everything works except for the following and VS is saying the ig:SpinnerSegmentedBusyAnimationPresenter does not exist.  ig is set to xmlns:ig="http://schemas.infragistics.com/xaml" and the rest of the references lik to ig:XamBusyIndicator work fine.
<Style TargetType="{x:Type ig:SpinnerSegmentedBusyAnimationPresenter}" BasedOn="{StaticResource {x:Type ig:SpinnerSegmentedBusyAnimationPresenter}}">
<Setter Property="Height" Value="217" />
<Setter Property="Width" Value="217" />
</Style>
Parents
No Data
Reply
  • 34430
    Verified Answer
    Hello AE,
    I have been investigating into this behavior, and the "BusyAnimationPresenter" classes have since had a namespace change. They now exist in the "igPrim" namespace pointing at xmlns:igPrim="http://schemas.infragistics.com/xaml/primitives". If you define this namespace and write the Style to target the SpinnerSegmentedBusyAnimationPresenter using this instead, you should be able to resolve that type.
    The issues related to the Samples Browser are known and have been resolved internally to reflect the correct namespace definition.
    Sincerely,
    Andrew
    Associate Developer
Children
No Data
