195
Force refresh xamGrid Cell Style
I write a poste months ago about an issue that I already have.
If you want more details about the issue please follow the link : https://www.infragistics.com/community/forums/f/ultimate-ui-for-wpf/109962/add-image-in-xamgrid-cell-like-excel-formula/523037?focus=true#517326
After many hours I think I found the issue reason.
In fact when the style's key is different between 2 cells the converter  is called, but if the style is the same, the converter is not called.
And that is a big issue for me.
For example if a have :
- a  cell with style : "styleDispo0" the cellcontrol will have the good background and the image will be displayed according to the converter result (visible or not visible)
- then if the cell just below the first one has a style : "styleDispo10" the background is different, and the image will also be displayed (or not) according to the converter's result.
So 2 differents style => 2 differents result => no problem
But if I have the following cases :
- a  cell with style : "styleDispo0" the cellcontrol will have the good background and the image will be displayed according to the converter result  (so that is the same behaviour)
- then if the cell just below the first one has the same style : "styleDispo0" the background is the same BUT the image will also be the same WHILE I hoped the converter will also be called one more time because the image should be the same.
So 1 different style => only 1 result (while the visibility behaviour is binded with a converter)
So is there any solution to force the style to reload all the binded value and at the end recompute the converter result ?
I have attached the file with the differents styles I use.
ViewCategorisationsDictionnary.zip
