I'm using XamMaskedEditor with Mask and SpinButton, but when there is a focus inside control at the end of the value (at the end of the 70%|) the spin button is disabled. When focus is between 70 and % the SpinButton is enabled. How make Spin button enabled when focus is set at the end of the value (at the end of the 70%)?
This field is used inside XamDataGrid:
<controls:XamDataGrid.FieldLayouts> <igDP:FieldLayout> <igDP:FieldLayout.Fields>
Here is the markup of the field:
<igDP:Field Name="MyPercentage" Label="{x:Static RFResourceRepository:RFResources.MyPercentage}"> <igDP:Field.Settings> <igDP:FieldSettings> <igDP:FieldSettings.EditorStyle> <Style TargetType="{x:Type igEditors:XamMaskedEditor}"> <Setter Property="Mask" Value="{}{number:0-100}%" /> <Setter Property="Background" Value="Transparent" /> <Setter Property="BorderThickness" Value="0" /> <Setter Property="BorderBrush" Value="Transparent" /> <Setter Property="Foreground" Value="Black" /> <Setter Property="SpinButtonDisplayMode" Value="Focused"/> </Style> </igDP:FieldSettings.EditorStyle> </igDP:FieldSettings> </igDP:Field.Settings> </igDP:Field>
Thank you for sending your xaml. I will test this out in a sample application. It seems like the editor realizes it's on a string token that can't be modified so it disables the spin buttons. If that's the case, I will follow up with our dev team to find out whether it's expected behavior.
In the meantime, please consider whether placing the % outside the editor is an acceptable workaround.
