Hello to all. can I use the same customization for xamdatagrid and xampivotgrid? I want to load the same filters with the same flags set / not set on both.
Hello Francesco,
Thank you for contacting Infragistics. Customizations are intended to be used solely in the control it was saved from. Therefore you cannot load identical customizations between controls. You will need to output them out as separate string or streams.
Please clarify your requirements and I will do my best to provide you with an alternative solution. Let me know if you have any questions.
