Hi Team,
We using xamgrid with 6 GroupColumns and 2 TextColumns which are IsFixable as True. Each GroupColumn setting visibilty as per data availablity. After upgrading infragisitics 16.2 the last GroupColumn which visibility true but not showing in XAMGRID. Please let me know any restiction of size of the xamgrid. Thanks for the support.
Hello Navin,
I have been unable to reproduce the behavior you describe with v16.2.20162.2237. The best way for us to assist you is if you provide a small isolated sample that we can run and use for debugging locally.
XamGrid.zip
Hi Mike,
Thanks for the reply.After upgrading (
current build 16.2.20162.2109 was replaced with 16.2.20162.2237) working fine.
Once gain thanks for the support.
