15
How to customize connection line between orgchart nodes
Is it possible to customize connection line between orgchart nodes depend on different logic? For example, I need to connect two nodes with solid line (default line style), but in some scenario I need to connect two nodes with dotted line.
However, the option LineEffect only have BlurEffect and DropShadowEffect. To do dotted line, do I need to look at other property?
I am using XamOrgChart Version 17.2
By the way, I looked at the other post about the similar issue. Just would like to see if there is any update on that.
https://www.infragistics.com/community/forums/f/ultimate-ui-for-wpf/85986/implementing-custom-line-style-between-particular-node-in-infragistics-xamorgchart
Thank you very much for your help.
  • 26325
    Advanced customization to the OrgChart's connection lines is considered to be a product idea. However I recommend using the XamDiagram control instead because you have more flexibility.
    The connection in the first node below has a StrokeDashArray property set to make the line appear dotted. Please visit our online documentation for more details about styling diagram nodes and connection lines.
    https://www.infragistics.com/help/wpf/xamdiagram-styling-items
    eg.
            <ig:XamDiagram x:Name="Diagram">
                <ig:DiagramNode Key="node1" Fill="{StaticResource DiagramNodeBrush1}" Stroke="{StaticResource DiagramNodeBrush2}" StrokeThickness="1" ShapeType="RoundedRectangle" Height="60" Width="90" Content="{x:Static res:DiagramStrings.BasiConfiguration_NewPosition}" Position="50,50" Foreground="White" />
                <ig:DiagramConnection StrokeDashArray="5 1" StartNodeKey="node1" Stroke="{StaticResource DiagramNodeBrush2}" Fill="{StaticResource DiagramNodeBrush2}" EndNodeKey="node2" ConnectionType="Straight" />
                <ig:DiagramNode Key="node2" Position="200,50" Fill="{StaticResource DiagramNodeBrush3}" Stroke="{StaticResource DiagramNodeBrush4}" StrokeThickness="1" ShapeType="RoundedRectangle" Height="60" Width="90" Content="{x:Static res:DiagramStrings.BasiConfiguration_HardWork}" Foreground="White"/>
                <ig:DiagramConnection StartNodeKey="node2" Fill="{StaticResource DiagramNodeBrush4}" Stroke="{StaticResource DiagramNodeBrush4}" EndNodeKey="node3" ConnectionType="Straight" />
                <ig:DiagramNode Key="node3" Fill="{StaticResource DiagramNodeBrush5}" Stroke="{StaticResource DiagramNodeBrush6}" StrokeThickness="1" ShapeType="RoundedRectangle" Height="60" Width="90" Content="{x:Static res:DiagramStrings.BasiConfiguration_Experience}" Position="350,50" Foreground="White"/>
                <ig:DiagramConnection Fill="{StaticResource DiagramNodeBrush6}" Stroke="{StaticResource DiagramNodeBrush6}" StartNodeKey="node3" EndNodeKey="node4" />
                <ig:DiagramNode Key="node4" Fill="{StaticResource DiagramNodeBrush7}" Stroke="{StaticResource DiagramNodeBrush8}" StrokeThickness="1" ShapeType="RoundedRectangle" Height="60" Width="90" Content="{x:Static res:DiagramStrings.BasiConfiguration_Promotion}" Position="500,50" Foreground="White"/>
                <ig:DiagramConnection Fill="{StaticResource DiagramNodeBrush8}" Stroke="{StaticResource DiagramNodeBrush8}" StartNodeKey="node4" EndNodeKey="node5" />
                <ig:DiagramNode Key="node5" Fill="{StaticResource DiagramNodeBrush9}" Stroke="{StaticResource DiagramNodeBrush10}" StrokeThickness="1" ShapeType="RoundedRectangle" Height="60" Width="90" Content="{x:Static res:DiagramStrings.BasiConfiguration_Retirement}" Position="500,200" Foreground="White" >
                    <ig:DiagramNode.ConnectionPoints>
                        <ig:DiagramConnectionPoint Position=".5,1" />
                    </ig:DiagramNode.ConnectionPoints>
                </ig:DiagramNode>
                <ig:DiagramConnection StartNodeKey="node4" EndNodeConnectionPointName="Left" StartNodeConnectionPointName="Right" EndNodeKey="node1" />
                <ig:DiagramConnection StartNodeKey="node4" EndNodeKey="node5" />
            </ig:XamDiagram>
