275
RecordFilter for nested FieldLayout
Hi.
I have a Xamdatagrid with nested records.
I'm trying to add a record filter to both levels of the grid, however, only the top level filter is working.
Is there something I'm doing wrong?
Please refer to the attached sample project.
There is a grid that should filter out the header records where the Detail count = 0 (this works).
The details where Qty = 0 should be filtered out as well (this doesn't work).
I've seen the post below where it's suggested that we add the filter in code in the FieldLayoutInitialized event handler, which I tried but still doesn't work.
https://www.infragistics.com/community/forums/f/ultimate-ui-for-wpf/36170/2009-v2-filtering-works-fine-for-root-fieldlayout-but-not-for-any-other-field-layout
TestXamdatagridFilters.zip
Thanks in advance for your help.
Ricardo
Parents Reply Children
No Data
