20
XamDataGrid Field with EditorStyle XamDateTimeEditor
I have a XamDatagrid with a column whose EditorStyle is set to XamDateTimeEditor.
1) i would like to set a dynamic ValueConstraint based on the value of another Field and
2) I want to be able to change the value of the EditorStyle in code behind based on a specif rule. I have tried looking all over the net for answer but to no avail
<igDP:Field Name="override_date" Converter="{StaticResource dateConverter}" Label="Override &#x0a;Date" AllowEdit="True" AllowRecordFiltering="False" Width="90">
<igDP:Field.Settings>
<igDP:FieldSettings>
<igDP:FieldSettings.EditorStyle>
<Style TargetType="{x:Type igEditors:XamDateTimeEditor}" >
<Setter Property="Mask" Value="mm/dd/yyyy"/>
<Setter Property="ValueConstraint">
<Setter.Value>
<igEditors:ValueConstraint></igEditors:ValueConstraint>
</Setter.Value>
</Setter>
</Style>
</igDP:FieldSettings.EditorStyle>
</igDP:FieldSettings>
</igDP:Field.Settings>
</igDP:Field>
