15
A question about ToolTip in XamDataChart when using TimeXAxis
I'm trying to use XamDataChart control in version 19.1, I modify the TimeAxisBreak property and tooltip of the sample "AxisBreaks" to this:
and then I modify the datasource to generate more data points,
When I run the sample, I found that the Tooltip doesn't show the correct "Date" property, and the date in the tooltip is not same as the time in timexaxis.
  • 25385
    The best way for us to assist you is if you provide a small isolated sample that we can run and use for debugging locally. If you are unable able to provide an isolated sample I may be able to give suggestions if you provide the code for your page.
