275
Treeview like XamScheduleView
I want to create a XamScheduleView where some recourses are locked and shown as Header for the next calendars. The Header schould have a function which allows to compress all calendarentrys (Like a Treeview does).
Here a example View:
The calendar of Header1 and Header2 are Locked.
If i click now on Button "TEST" i want that all Resources till Header2 are collapsed or invisble. If i click again on Button "TEST" the resouces should be visible again.
Do you have any recommondation i can achieve this?
Best regards
Dominik
  • 25265
    Hello Matthias,
    Thank you for contacting Infragistcis!
    If you want to achieve this yourself, you would have to remove the resources when you click on the button for the header you want to collapse.
    After investigating this and doing some research, having collapsible header/resource trees has been determined to be a product idea. You can suggest new product ideas for future versions (or vote for existing ones) at <www.infragistics.com/.../ideas>.
    Submitting your idea will allow you to communicate directly with our product management team, track the progress of your idea at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
    Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. You can also link back to this thread for additional details.
    Thank you in advance to submitting your product idea.
