2660
xamNumericEditor: Disable turn arround spin button increment
is it posible to disable the behavoir, that if the upper or lower limit is reached, it begins from the min or max value?
E.g. if the mask is nnn.
  • When the current value is 0 and I press the decrement button it show 999.
  • When the current value is 999 and I press the increment button it show 0.
This behaviour is not wanted.
  • 29630
    Hello Markus,
    I have been investigating into the behavior you are seeing, and in order to prevent the “wrap” on the spin button, I would recommend setting the SpinWrapBehavior property on the XamNumericEditor to “NoWrapping.” This will prevent the behavior you are seeing.
