15
Customize WPF Menu Tool with a Control Template
I am looking for a Menu Tool with something like this.
But here in place of LargeImage I want to add my own svg xaml(controltemplate). Please suggest how i can achieve this.
  • 29650
    Hello Srajan,
    From the sample screenshot that you have provided, it appears that you are already using the XamRibbon and a MenuTool, although I am unsure if you are currently using one of our built-in themes, such as RoyalDark or MetroDark, or if you have provided your own styling. If this is not the case, please let me know as the following is based on that impression.
    If you are looking to re-template the LargeImage area of the MenuTool in the XamRibbon control, I would recommend bringing in the default styles for the MenuTool and MenuButtonArea and modifying their default control templates. These can be found in the RibbonGeneric.xaml file commonly found at the following directory when Infragistics tools are installed:
    C:\Program Files (x86)\Infragistics\<version>\WPF\DefaultStyles\Ribbon
    Note, if you are using the MetroDark or RoyalDark themes, you may want to look in the RibbonMetroDark.xaml and RibbonRoyalDark.xaml files at the same directory instead.
