50
Issue with changing the style of XamPropertyGrid
Hi!
I am having an issue with changing the style of the XamPropertyGrid.
I am using Infragistics 18.1.20181.324.
I took an example from the thread
https://www.infragistics.com/community/forums/f/ultimate-ui-for-wpf/110051/default-property-grid-editors
PropertyGridDefaultEditorsCase.zip
and according to the thread
https://www.infragistics.com/community/forums/f/ultimate-ui-for-wpf/108746/xampropertygrid-description-area-display-an-image
I added the generic.shared.xaml file.
This file is located under the C:\Program Files (x86)\Infragistics\2018.1\WPF\DefaultStyles\PropertyGrid
to the solution and merged the resource dictionaries
<ResourceDictionary Source="Themes\generic.xaml" />
in MainWindow.xaml.
Nothing else.
The original looks like this
When you hover over the items it is gray backcolor and black forecolor.
A selected item is blue backcolor and white forecolor.
The modified example, shows a gray backcolor and a black forecolor when you hover:
but as soon as you select an item the selected item has blue backcolor and white forecoler and all other items switch to white forecolor:
and hovering over the items:
I took a look at generic.shared.xaml  and the line which causes the troubles is in Style
PropertyGridPropertyItemView
line no. 771
<ColorAnimation Duration="0" To="White" Storyboard.TargetProperty="(TextBlock.Foreground).(SolidColorBrush.Color)" Storyboard.TargetName="displayName"/>
if this line is commented the text stays black, but looks not so fine when it is selected:
I was not able to fix this myself.
Main intention is to adjust the some colors, some other visual items and the PropertyGridDescriptionAreaControl .
I've attached the modified project:
Thx, Christoph
Parents Reply Children
No Data
