100
Some questions about XamDataGrid
Hi staff,
i'm new of WPF and of XamDataGrid. I'm working about a new project and i some issues i can't solve.
This is XAML of the XamDataGrid
<igDP:XamDataGrid x:Name="GRD_CR_1" Grid.Column="1" VerticalAligment="Top"   GroupByAreaMode="MultipleFieldLayoutsCompact" BindToSampleData="False" InitializeRecord="Grd_InitializeRecord">
            <igDP:XamDataGrid.Resources>
                <Style TargetType="{x:Type igDP:CellValuePresenter}">
                    <Setter Property="BorderThickness" Value="0,0,1,1" />
                    <Setter Property="BorderBrush"  Value="Black" />
                </Style>
            </igDP:XamDataGrid.Resources>
            <igDP:XamDataGrid.FieldSettings>
                <igDP:FieldSettings AllowEdit="False" AllowFixing="No" AllowGroupBy="True" AllowSummaries="False" CellClickAction="SelectCell" />
            </igDP:XamDataGrid.FieldSettings>
            <igDP:XamDataGrid.FieldLayouts>
                <igDP:FieldLayout>
                    <igDP:FieldLayout.Fields>
                        <igDP:Field Name="P0700" Visibility="Collapsed" />
                        <igDP:Field Name="U_P0700" Label="07" Width="28px" BindingType="Unbound" />
                    </igDP:FieldLayout.Fields>
                </igDP:FieldLayout>
            </igDP:XamDataGrid.FieldLayouts>
        </igDP:XamDataGrid>
1) Is there a way to see a preview of the XamDataGrid without writing BindToSampleData="True"?
2) I need to color the cell. I tried to achieve it writing the code you can see above but in running is rendered badly (except the first row). Why?
3) I have to change cell's background color at run-time.
I tried with this code but it doesn't work (i get a null exception in FromCell).
Where am i wrong?
private void Grd_InitializeRecord(object sender, Infragistics.Windows.DataPresenter.Events.InitializeRecordEventArgs e)
            if (e.Record is DataRecord)
                var dr = (DataRecord)e.Record;
                var brush = new SolidColorBrush(Color.FromArgb(0, 63, 157, 211));
                if (int.Parse(dr.Cells["P0700"].Value.ToString()) != 0)
                    CellValuePresenter.FromCell(dr.Cells["U_P0700"]).Background = brush;
4) Last question (this is caused by my low level of WPF):
I prepared a XamDataGrid, and that is my default.
I need to copy it (at run-time) and paste it in the other grid of my Windows, changing the DataSource.
Someone can give me some advises?
Thank you very much,  and sorry for my bad English.
