395
Xamdatagrid IDataErrorInfo only works for newly added records
I change my error condition after adding first two records, but instead of all items, I only get error message for newly added ones.
   <infragistic:XamDataGrid.FieldLayoutSettings>
                                            <infragistic:FieldLayoutSettings AutoGenerateFields="False"
                                            AutoFitMode="Always"
                                            AddNewRecordLocation="OnTopFixed"
                                            AllowAddNew="False"
                                            SupportDataErrorInfo="RecordsAndCells"
                                            DataErrorDisplayMode="Highlight"
                                            AllowDelete="True" SelectionTypeRecord="Single"/>
                                        </infragistic:XamDataGrid.FieldLayoutSettings>
                                        <infragistic:XamDataGrid.FieldLayouts>
                                            <infragistic:FieldLayout>
                                                <infragistic:FieldLayout.Fields>
                                                    <infragistic:Field Name="Name" Label="Name"></infragistic:Field>
                                                    <infragistic:Field Name="GuideWeight" Label="Guide weight" Visibility="{infragistic:FieldBinding ShowGuideWeight,  Converter ={StaticResource boltoVis}}">
                                                </infragistic:FieldLayout.Fields>
                                            </infragistic:FieldLayout>
                                        </infragistic:XamDataGrid.FieldLayouts>
                                    </infragistic:XamDataGrid>
here is my data grid, and my IDATAErrorinfo code
        private static readonly string[] ValidateProperties =
            nameof(WellLogVersion),
            nameof(GuideWeight),
            nameof(Name)
        public bool IsValid
            get
                foreach (string property in ValidateProperties)
                    if (GetValidationError(property) != null)
                        return false;
                return true;
        public override string GetValidationError(String propertyName)
            string Error = null;
            switch (propertyName)
                case nameof(GuideWeight):
                    Error = Validate(nameof(GuideWeight));
                    break;
                //case nameof(WellLogVersion):
                case nameof(Name):
                    Error = Validate(nameof(WellLogVersion));
                    break;
            return Error;
        private string Validate(string prop)
            var errors = _model.ParentEpbdo.Errors.Where(x => Equals(x.PropertyName, prop));
            string message = "";
            foreach (var error in errors)
                message += PropertyBuilderDOErrorMessages.GetErrorMessage(error.ErrorCode) + Environment.NewLine;
            return message;
what am I missing ?
  • 100
    IDataErrorInfo interface found in the .NET Framework requires the implementation of the following properties:
     public string this[string columnName] => throw new NotImplementedException();
     public string Error => throw new NotImplementedException();
    More information about DataErrorValidation can be read on our website here.
    For further reference, please check the attached sample, where validation of both pre-loaded and newly created entries can be observed.
    Should you have any other questions, please let me know.
    Sincerely,
    Tihomir Tonev
    Associate Software Developer
    4214.sample.zip
