20
Ribbon Designer not working when using NuGet packages rather than assembly references to Infragistics libraries
I've created a new application window with a ribbon (basically following the workflow in youtube video Getting Started with WPF xamRibbon https://www.youtube.com/watch?v=BHpQJcPVaX0).
If, however, I replace the Infragistics Assembly references with NuGet package references (using the NuGet packages supplied in the Infragistics Platform installation, and added to our local NuGet feed) then I no longer get the ribbon designer.
If there a way of getting the ribbon designer to work when using NuGet package references rather than using assembly refences?
We're currently using version 19.1.84 of the Infragistics packages.
Thanks.
