55
Two parent FieldLayouts with same Child FieldLayouts
I have an issue where I have a Three tier hierarchy and a two tier hierarchy.  The field layouts are described for each tier, However one FieldLayout is repeated in both hierarchys. This causes the FieldLayout display to only work for one: either the 3 tier hierarchy  or the two tier hierarchy . Never both of them at the same time.
So my question is can you have a FieldLayout with two different ParentFieldLayoutKey
Current solution is to describe the same FieldLayout twice, giving each FieldLayout a different ParentFieldLayoutKey. which works:
<DataPresenter:FieldLayout Key="DadModel">            <!--  DadModel can be two different classes DadModel or GroupModel -->
	<DataPresenter:Field Name="GroupComponentModels" />
	<DataPresenter:Field Name="SonModels" />
</DataPresenter:FieldLayout>
<DataPresenter:FieldLayout Key="GroupComponentModel">
<DataPresenter:FieldLayout Key="SonModel" ParentFieldLayoutKey="DadModel">
<DataPresenter:FieldLayout Key="SonModel" ParentFieldLayoutKey="GroupComponentModel">
<!--  All the classes -->
Class DadBase,
Class DadModel:DadBase,
Class GroupModel:DadBase,
Class GroupComponentModel:TModel,
Class SonModel
However I don't like this as the FieldLayout has to be repeated twice. Duplicate xaml, Is there a better solution ?
