35
Data disappearing from cells when scrolling through XamDataGrid
Hi Team,
We have a Xamdatagrid with around 20 columns which are editable and virtualization is enabled on the grid , we are able to load and edit the data without any issues .
But when we use the grid’s scrollbar to view the records , the data from some of the columns (specifically columns which use XamMultiColumnCombo)  are disappearing as we scroll .
We have tried to set the RecordContainerGenerationMode to lazyload or preload which solves the issue , but has significant performance impact .So we can't go with this solution.
This is happening specifically on the cells which use XamMultiColumnCombo editor , the selected item is getting triggered on the combo when we use the scrollbar on the xamdatagrid.
Any help to resolve this issue is greatly appreciated.
Current version of IG : 14.1
Here is the snippet of the column in which we are noticing the above issue,
<dataPresenter:UnboundField Label="Order Placer" Visibility="{Binding Source={StaticResource Proxy}, Path=Data.ShowCol, Converter={StaticResource BoolToCollapseVisibilityConverter}}">
<dataPresenter:Field.Settings>
<dataPresenter:FieldSettings AllowEdit="True" LabelTextAlignment="Center" LabelTextWrapping="Wrap" Width="140"
CellValuePresenterStyle="{StaticResource EditableCellValuePresenterStyle}">
<dataPresenter:FieldSettings.EditorStyle>
<Style TargetType="{x:Type editors:XamTextEditor}">
<Setter Property="Template">
<Setter.Value>
<ControlTemplate TargetType="{x:Type editors:XamTextEditor}">
<Grid IsEnabled="{Binding DataItem.IsEnabled}">
<StackPanel DataContext="{Binding DataItem.DsViewModel}">
<ig:XamMultiColumnComboEditor
x:Name="TestCombo"
AutoGenerateColumns="False"
DropDownButtonDisplayMode="Always"
SelectedItemsResetButtonVisibility="Collapsed"
ItemsSource="{Binding Orders}"
DisplayMemberPath="Name"
SelectedItem="{Binding SelectedOrder, Mode=TwoWay, UpdateSourceTrigger=PropertyChanged}"
FilterMode="FilterOnAllColumns"
MinDropDownWidth="320"
<ig:XamMultiColumnComboEditor.Columns>
<ig:TextComboColumn Key="Name"/>
</ig:XamMultiColumnComboEditor.Columns>
</ig:XamMultiColumnComboEditor>
</StackPanel>
</Grid>
</ControlTemplate>
</Setter.Value>
</Setter>
<Setter Property="EditTemplate">
<Setter.Value>
x:Name="OrderPlacerCombo"
</StackPanel>
</Grid>
</ControlTemplate>
</Setter.Value>
</Setter>
</Style>
</dataPresenter:FieldSettings.EditorStyle>
</dataPresenter:FieldSettings>
</dataPresenter:Field.Settings>
</dataPresenter:UnboundField>
