I havea XamDatagrid with fields in some columsn and PNG icons as ImageFields in otrher columns. These are green UP and red Down arrows.
When I export thee to Excel using the Excel exporter, the imags appear correctly in the spreadsheet, but I get loads of exceptions thrown - something to do with Bitmap.Media.
This slows it down very significantly, but it eventually gets there and gives me the result I want.
Should i be using a different format of image file, or should I be doing something differently ?
Here is a sample of my XAML
<ig:Field Label="Cases" AlternateBinding="{Binding Casesthisyear, Mode=TwoWay}" HorizontalContentAlignment="Right" Format="##,###,###"> <ig:Field.Settings> <ig:FieldSettings AllowHiding="Default" AllowEdit="False" Width="auto" /> </ig:Field.Settings> </ig:Field>
<ig:Field Label="Cases LY" AlternateBinding="{Binding Caseslastyear, Mode=TwoWay}" HorizontalContentAlignment="Right" Format="##,###,###"> <ig:Field.Settings> <ig:FieldSettings AllowHiding="Default" AllowEdit="False" Width="auto" /> </ig:Field.Settings> </ig:Field>
<ig:ImageField AlternateBinding="{Binding Casesthisyearicon, Mode=TwoWay}" Width="25" ImageHeight="15" ImageWidth="20" />
Casesthisyearicon will contain one of 3 values, such as
"pack://application:,,,/SFE_UI;component/Images/Icons/icons8-thick-arrow-pointing-down-96.png"
Hello Gordon,
Thank you for your post. Are you getting these images from your underline datasource ? If so, then can you change your AlternateBinding to name binding , something like this , and check if you still getting these Bitmap.Media exception?
<igDP:ImageField Name="Casesthisyearicon" ImageHeight="30" ImageWidth="30" />
If you still getting the exceptions , the best way for us to assist you is if you provide a small isolated sample that we can run and use for debugging locally.
Sincerely,Divya Jain
