135
How to retrieve a WorksheetRegion from an ExcelCalcValue
I've defined a custom function in Excel CalcEngine.
Some of the function parameters are Regions defined in Excel
=MyFunction(125,A1:A23,D5:D56)
In my code, when I receive the parameters, they are ExcelCalcValue.
How can I get the WorksheetRegion from the ExcelCalcValue ?
The Value property returns a Infragistics.Documents.Excel.FormulaUtilities.CalcEngine.RegionCalcReference type, which is not accessible, so I can't cast the result and access its Region property.
The GetResolvedValue() or ToArrayProxy returns a Infragistics.Documents.Excel.FormulaUtilities.CalcEngine.RegionCalcReference.RegionArrayProxy which is not accessible.
ToString() returns the class Type
Is there any way to retrieve the region ?
Thank you
  • 30830
    Verified Answer
    Hello Arnaud,
    I have been investigating into the behavior you are looking to achieve to get a WorksheetRegion from an ExcelCalcValue, and while you cannot really get it directly from the ExcelCalcValue, you can get it from the ExcelCalcNumberStack in the Evaluate() method of your custom function.
    The Excel Engine is smart enough to know when a region is placed within the parameters of the function used, and so you can get the parameter corresponding to a Region by using the following code:
            protected override ExcelCalcValue Evaluate(ExcelCalcNumberStack numberStack, int argumentCount)
                for(int i=0; i<numberStack.Count(); i++)
                    var argument = numberStack.Pop();
                    if (argument.IsReference)
                        var argReference = argument.ToReference();
                        var region = argReference.Context;
                return new ExcelCalcValue(1000);
    I hope this helps. Please let me know if you have any other questions or concerns on this matter.
